Ana içeriğe geç
Lenovo V14-IIL Screen Bezel Replacement
Neye ihtiyacın var
  1. Lenovo V14-IIL Screen Bezel Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo V14-IIL Screen Bezel Replacement, Back Panel: adım 1, 2 resimden 2.
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Flip your laptop over and place on a flat surface so you can access the screws on the base cover.
    • Remove the six 7 mm screws from the back panel of the laptop using a Phillips #0 screwdriver.
    • Remove the four 4 mm screws from the bottom edge of the laptop using a Phillips #0 screwdriver.
  2. Lenovo V14-IIL Screen Bezel Replacement: adım 2, 1 resimden 1.
    • Use an iFixit opening tool to pry apart the case by sliding it along each side of the laptop.
    • You may need to move the tool to different locations to fully release the back cover.
  3. Lenovo V14-IIL Screen Bezel Replacement: adım 3, 1 resimden 1.
    • Lift away the back panel and set it aside.
  4. Lenovo V14-IIL Screen Bezel Replacement, Display Assembly: adım 4, 2 resimden 1. Lenovo V14-IIL Screen Bezel Replacement, Display Assembly: adım 4, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the four 5 mm screws from the hinges of the laptop.
  5. Lenovo V14-IIL Screen Bezel Replacement: adım 5, 1 resimden 1.
    • Lift up the latch and gently pull the display cable free.
  6. Lenovo V14-IIL Screen Bezel Replacement: adım 6, 2 resimden 1. Lenovo V14-IIL Screen Bezel Replacement: adım 6, 2 resimden 2.
    • Using the spudger, disconnect the two wireless LAN cables (black and gray) from the wireless LAN card.
    • Remove the LAN cables from the three brackets on the fan.
  7. Lenovo V14-IIL Screen Bezel Replacement: adım 7, 1 resimden 1.
    • Ensure that all cables and hinges are detached.
    • Lift the display assembly away from the base.
  8. Lenovo V14-IIL Screen Bezel Replacement, Screen Bezel: adım 8, 2 resimden 1. Lenovo V14-IIL Screen Bezel Replacement, Screen Bezel: adım 8, 2 resimden 2.
    • Slide the cable hinge cover to the right.
    • Pull the part away from the screen.
  9. Lenovo V14-IIL Screen Bezel Replacement: adım 9, 2 resimden 1. Lenovo V14-IIL Screen Bezel Replacement: adım 9, 2 resimden 2.
    • Use the iFixit opening tool to separate the bezel panel.
    • Slide the opening tool all the way around to loosen the bezels on all sides.
    • You may need to use the tool to gently loosen the adhesive tape.
    • Lift away the bezel panel.
Sonuç
Kristen Gismondi
92.096 İtibar
241 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.455 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 54
