Ana içeriğe geç
Lenovo V15-ADA Wi-Fi Card Replacement
Neye ihtiyacın var
  1. Lenovo V15-ADA Wi-Fi Card Replacement, Back Panel Assembly: adım 1, 2 resimden 1. Lenovo V15-ADA Wi-Fi Card Replacement, Back Panel Assembly: adım 1, 2 resimden 2.
    • Remove the 10 marked screws using a Phillips #1 screwdriver from the back plate.
    • M2.5 × 7 mm, Phillips-head (6) (RED circles)
    • M2.5 × 4 mm, Phillips-head (4) (ORANGE circles)
  2. Lenovo V15-ADA Wi-Fi Card Replacement: adım 2, 2 resimden 1. Lenovo V15-ADA Wi-Fi Card Replacement: adım 2, 2 resimden 2.
    • After all 10 screws have been removed, insert a spudger between the bottom plate and the housing and slide across.
    • Repeat for all 4 sides until loose.
    • Pop off the back plate and set aside.
  3. Lenovo V15-ADA Wi-Fi Card Replacement, Wi-Fi Card: adım 3, 1 resimden 1.
    • Remove the Black wire with your fingers or small ESD-safe tweezers.
  4. Lenovo V15-ADA Wi-Fi Card Replacement: adım 4, 1 resimden 1.
    • Remove Grey wire.
  5. Lenovo V15-ADA Wi-Fi Card Replacement: adım 5, 1 resimden 1.
    • Unscrew screw holding Wi-Fi card in place.
    • 1x M2 x 3mm, Phillips #1.
  6. Lenovo V15-ADA Wi-Fi Card Replacement: adım 6, 1 resimden 1.
    • Card will lift up after screw is out of place.
  7. Lenovo V15-ADA Wi-Fi Card Replacement: adım 7, 1 resimden 1.
    • Pull Wi-Fi card out of slot.
Sonuç
Jacob Schorr
442 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 41
Her zaman: 204
