Ana içeriğe geç
Lenovo Vibe Z2 Pro Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo Vibe Z2 Pro Motherboard Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: adım 1, 2 resimden 1. Lenovo Vibe Z2 Pro Motherboard Replacement, Lenovo Vibe Z2 Pro Backplate Disassembly: adım 1, 2 resimden 2.
    • Remove the 4.9 mm torx head screws located on the camera plate on the back of the phone
  2. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the 3.65 mm Torx head screws at the bottom of the phone.
  3. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 3, 2 resimden 1. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 3, 2 resimden 2.
    • Remove the SIM card tray by pushing a pin into the hole on the side of the phone.
  4. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 4, 2 resimden 1. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 4, 2 resimden 2.
    • Push the Spudger along the gap between the phone and the backplate to separate them.
  5. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 5, 1 resimden 1.
    • Carefully pull the backplate away from the phone.
  6. Lenovo Vibe Z2 Pro Motherboard Replacement, Battery: adım 6, 2 resimden 1. Lenovo Vibe Z2 Pro Motherboard Replacement, Battery: adım 6, 2 resimden 2.
    • Peel away protective the film using your hands.
  7. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 7, 2 resimden 1. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove any adhesive strips holding the battery in place gently using a fingernail or spudger.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
  8. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 8, 1 resimden 1.
    • Disconnect the orange battery ribbon cable by gently lifting with a spudger.
  9. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 9, 3 resimden 1. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 9, 3 resimden 2. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 9, 3 resimden 3.
    • Insert a fingernail or spudger into either side of the battery and lift upward.
    • Remove the battery from phone.
  10. Lenovo Vibe Z2 Pro Motherboard Replacement, Motherboard: adım 10, 3 resimden 1. Lenovo Vibe Z2 Pro Motherboard Replacement, Motherboard: adım 10, 3 resimden 2. Lenovo Vibe Z2 Pro Motherboard Replacement, Motherboard: adım 10, 3 resimden 3.
    • Remove the 3.15mm Phillips Head #000 screws from motherboard.
  11. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 11, 3 resimden 1. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 11, 3 resimden 2. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 11, 3 resimden 3.
    • Disconnect the two ribbon cables by gently lifting on the black hinges and pulling away with tweezers
  12. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 12, 2 resimden 1. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 12, 2 resimden 2.
    • Gently disconnect the rear-camera connector
  13. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 13, 2 resimden 1. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 13, 2 resimden 2.
    • Gently remove the front-facing camera by gently lifting on the connector tab.
    • Remove the other connector by gently lifting with a spudger.
  14. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 14, 2 resimden 1. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 14, 2 resimden 2.
    • Pry off the plastic brace along the top edge of the phone
  15. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 15, 2 resimden 1. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 15, 2 resimden 2.
    • Remove the antenna connected to the bottom piece of the screen plate
  16. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 16, 1 resimden 1.
    • Gently lift the motherboard off the frame
    • Pull the camera out from behind the motherboard
  17. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 17, 3 resimden 1. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 17, 3 resimden 2. Lenovo Vibe Z2 Pro Motherboard Replacement: adım 17, 3 resimden 3.
    • Using a spudger, disconnect the charging port assembly cable and the screen connection cable.
    • Remove the motherboard completely.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Mitchell Beall
407 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 18-3, Blackwell Fall 2016 USF Tampa, Team 18-3, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S18G3
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 2,038
