Ana içeriğe geç
Fix Your Stuff
Right to Repair
Parts & Tools
Giriş
This guide will document the process of upgrading or replacing memory in a Lenovo X200 laptop or tablet.
  1. 1. Unscrew the two phillips #1 size screws that hold the panel to access the two memory modules.
    • 1. Unscrew the two phillips #1 size screws that hold the panel to access the two memory modules.
  2. 2. Remove the panel to access the memory modules.
    • 2. Remove the panel to access the memory modules.
  3. Note: If only one DIMM is used on the computer, the card must be installed in SLOT-0 ( a ), not in SLOT-1 ( b ).
    • Note: If only one DIMM is used on the computer, the card must be installed in SLOT-0 ( a ), not in SLOT-1 ( b ).
    • Remove DIMM by gently spreading the socket connectors up and down as shown in the direction of the arrows and pull the DIMM out.
    • Insert the notched end of the DIMM into the socket.
    • Press the DIMM firmly, and pivot it until it snaps into the place.
    • Make sure that it is firmly fixed in the slot and does not move easily.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
James Finch
1.454 İtibar
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 21
Her zaman: 284
