Ana içeriğe geç
Lenovo Y410P Hard Drive/SSD Replacement
Neye ihtiyacın var
  1. Lenovo Y410P Hard Drive/SSD Replacement, Removal of Bottom Panel: adım 1, 2 resimden 1. Lenovo Y410P Hard Drive/SSD Replacement, Removal of Bottom Panel: adım 1, 2 resimden 2.
    • Remove the eight M2.5x8mm Phillips head screws that fasten the bottom cover.
    • For the Lenovo Y510P, there's another screw in the center that has to be removed.
    • Lift bottom cover off and set aside.
    • On the Lenovo Y510P, use a black spudger around the outside edge to pop loose the bottom panel.
  2. Lenovo Y410P Hard Drive/SSD Replacement, Removal of Hard Drive: adım 2, 2 resimden 1. Lenovo Y410P Hard Drive/SSD Replacement, Removal of Hard Drive: adım 2, 2 resimden 2.
    • If you intend to reuse this Hard Drive/SSD, be careful with the removal. Hard impact may result in damage.
    • First remove the two screws at the end of the Hard Drive bracket then slide the Hard Drive/SSD out of its seat.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Brandon
527 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-21, Maness Winter 2015 Cal Poly, Team 21-21, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G21
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 38
Her zaman: 8,670
