Ana içeriğe geç
Lenovo Y50-70 Touch Fan Replacement
Neye ihtiyacın var
  1. Lenovo Y50-70 Touch Fan Replacement, Back: adım 1, 2 resimden 1. Lenovo Y50-70 Touch Fan Replacement, Back: adım 1, 2 resimden 2.
    • Remove all twelve 6 mm screws from the back of the laptop using a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    • Make sure to turn off the computer first!
  2. Lenovo Y50-70 Touch Fan Replacement: adım 2, 2 resimden 1. Lenovo Y50-70 Touch Fan Replacement: adım 2, 2 resimden 2.
    • Gently pull the back cover off the laptop. It should come off easily.
  3. Lenovo Y50-70 Touch Fan Replacement, Fan: adım 3, 2 resimden 1. Lenovo Y50-70 Touch Fan Replacement, Fan: adım 3, 2 resimden 2.
    • Remove the three 3.5 mm screws from the fan with a Philips #1 screwdriver.
  4. Lenovo Y50-70 Touch Fan Replacement: adım 4, 3 resimden 1. Lenovo Y50-70 Touch Fan Replacement: adım 4, 3 resimden 2. Lenovo Y50-70 Touch Fan Replacement: adım 4, 3 resimden 3.
    • Pull the wire tabs up one at a time to separate them from the motherboard.
    • Do not pull too hard on the wire tabs. It may damage the connection between the wires and motherboard.
  5. Lenovo Y50-70 Touch Fan Replacement: adım 5, 3 resimden 1. Lenovo Y50-70 Touch Fan Replacement: adım 5, 3 resimden 2. Lenovo Y50-70 Touch Fan Replacement: adım 5, 3 resimden 3.
    • Remove the black and white antenna cables from the wireless card.
    • Do not pull too hard on the antenna cables, as it might damage the connection to the wireless card.
  6. Lenovo Y50-70 Touch Fan Replacement: adım 6, 3 resimden 1. Lenovo Y50-70 Touch Fan Replacement: adım 6, 3 resimden 2. Lenovo Y50-70 Touch Fan Replacement: adım 6, 3 resimden 3.
    • Lift up the fan slightly.
    • Gather the antenna cables(black and white) and speaker wires (red, black, blue, and white). Carefully move them away from the fan.
  7. Lenovo Y50-70 Touch Fan Replacement: adım 7, 2 resimden 1. Lenovo Y50-70 Touch Fan Replacement: adım 7, 2 resimden 2.
    • Lift the fan off of the laptop.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Vivian
351 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-1, Maness Winter 2015 Cal Poly, Team 18-1, Maness Winter 2015 üyesi
CPSU-MANESS-W15S18G1
5 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 9,307
