Ana içeriğe geç
Lenovo Y50-70 Touch Heat Sink Replacement
Neye ihtiyacın var
  1. Lenovo Y50-70 Touch Heat Sink Replacement, Heat Sink: adım 1, 2 resimden 1. Lenovo Y50-70 Touch Heat Sink Replacement, Heat Sink: adım 1, 2 resimden 2.
    • Remove all twelve 6 mm long screws on the back of the laptop with a Phillips #1 screwdriver.
    • Apply a lot of pressure to prevent the screws from stripping.
    • Make sure to turn off the computer first!
  2. Lenovo Y50-70 Touch Heat Sink Replacement: adım 2, 2 resimden 1. Lenovo Y50-70 Touch Heat Sink Replacement: adım 2, 2 resimden 2.
    • Pull off the back cover of the laptop. It should come off easily.
  3. Lenovo Y50-70 Touch Heat Sink Replacement: adım 3, 2 resimden 1. Lenovo Y50-70 Touch Heat Sink Replacement: adım 3, 2 resimden 2.
    • Remove all six 7mm screws from the heat sink using the Phillips #1 screwdriver.
  4. Lenovo Y50-70 Touch Heat Sink Replacement: adım 4, 2 resimden 1. Lenovo Y50-70 Touch Heat Sink Replacement: adım 4, 2 resimden 2.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Kevin Silken
418 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 18-1, Maness Winter 2015 Cal Poly, Team 18-1, Maness Winter 2015 üyesi
CPSU-MANESS-W15S18G1
5 Üyeler
15 adet Kılavuz yazıldı
Bir Yorum
Hope someone see this cmt. I cannot lift up the heat sink for some reason. All 6 screws are removed. Any advice?
Dalala - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 6,462
