Ana içeriğe geç
Lenovo Y50-70 Touch Motherboard Replacement
Neye ihtiyacın var
  1. Lenovo Y50-70 Touch Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. Lenovo Y50-70 Touch Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. Lenovo Y50-70 Touch Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Use a Phillips #1 screwdriver to unscrew and remove the ten 6 mm screws on the back of the laptop.
    • Grab and pull off the back.
  2. Lenovo Y50-70 Touch Motherboard Replacement: adım 2, 3 resimden 1. Lenovo Y50-70 Touch Motherboard Replacement: adım 2, 3 resimden 2. Lenovo Y50-70 Touch Motherboard Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the battery.
    • Grab the battery cable and gently pull it free from the cable connector.
    • Remove the battery.
  3. Lenovo Y50-70 Touch Motherboard Replacement: adım 3, 3 resimden 1. Lenovo Y50-70 Touch Motherboard Replacement: adım 3, 3 resimden 2. Lenovo Y50-70 Touch Motherboard Replacement: adım 3, 3 resimden 3.
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws that secure the hard drive.
    • Grab the marked cable attached to the hard drive, and gently pull to unplug.
    • Remove the hard drive from the laptop.
  4. Lenovo Y50-70 Touch Motherboard Replacement: adım 4, 3 resimden 1. Lenovo Y50-70 Touch Motherboard Replacement: adım 4, 3 resimden 2. Lenovo Y50-70 Touch Motherboard Replacement: adım 4, 3 resimden 3.
    • Grab marked cables and pull them out from their plug-in.
  5. Lenovo Y50-70 Touch Motherboard Replacement: adım 5, 3 resimden 1. Lenovo Y50-70 Touch Motherboard Replacement: adım 5, 3 resimden 2. Lenovo Y50-70 Touch Motherboard Replacement: adım 5, 3 resimden 3.
    • Grab the top set of marked cables and pull up to remove them.
    • Grab the lower marked cable and pull it out from their plug.
  6. Lenovo Y50-70 Touch Motherboard Replacement: adım 6, 3 resimden 1. Lenovo Y50-70 Touch Motherboard Replacement: adım 6, 3 resimden 2. Lenovo Y50-70 Touch Motherboard Replacement: adım 6, 3 resimden 3.
    • Grab marked cables and pull up to unplug.
  7. Lenovo Y50-70 Touch Motherboard Replacement: adım 7, 2 resimden 1. Lenovo Y50-70 Touch Motherboard Replacement: adım 7, 2 resimden 2.
    • Grab marked cables and pull out to unplug.
  8. Lenovo Y50-70 Touch Motherboard Replacement: adım 8, 3 resimden 1. Lenovo Y50-70 Touch Motherboard Replacement: adım 8, 3 resimden 2. Lenovo Y50-70 Touch Motherboard Replacement: adım 8, 3 resimden 3.
    • Grab the black tab on top of the cable and pull up to unplug.
  9. Lenovo Y50-70 Touch Motherboard Replacement: adım 9, 3 resimden 1. Lenovo Y50-70 Touch Motherboard Replacement: adım 9, 3 resimden 2. Lenovo Y50-70 Touch Motherboard Replacement: adım 9, 3 resimden 3.
    • Lift the black tab on top of the marked cable.
    • Grab the colored tab on the cable and pull to remove the cable.
  10. Lenovo Y50-70 Touch Motherboard Replacement: adım 10, 3 resimden 1. Lenovo Y50-70 Touch Motherboard Replacement: adım 10, 3 resimden 2. Lenovo Y50-70 Touch Motherboard Replacement: adım 10, 3 resimden 3.
  11. Lenovo Y50-70 Touch Motherboard Replacement: adım 11, 3 resimden 1. Lenovo Y50-70 Touch Motherboard Replacement: adım 11, 3 resimden 2. Lenovo Y50-70 Touch Motherboard Replacement: adım 11, 3 resimden 3.
  12. Lenovo Y50-70 Touch Motherboard Replacement: adım 12, 3 resimden 1. Lenovo Y50-70 Touch Motherboard Replacement: adım 12, 3 resimden 2. Lenovo Y50-70 Touch Motherboard Replacement: adım 12, 3 resimden 3.
    • Lift the black tab on top of the marked cables.
    • Grab the colored tab on the cables and pull to remove the cables.
  13. Lenovo Y50-70 Touch Motherboard Replacement: adım 13, 3 resimden 1. Lenovo Y50-70 Touch Motherboard Replacement: adım 13, 3 resimden 2. Lenovo Y50-70 Touch Motherboard Replacement: adım 13, 3 resimden 3.
    • Use a Phillips #1 screwdriver to unscrew and remove the six 7 mm screws from the heat sink.
    • Grab and lift the heatsink off the motherboard.
  14. Lenovo Y50-70 Touch Motherboard Replacement: adım 14, 3 resimden 1. Lenovo Y50-70 Touch Motherboard Replacement: adım 14, 3 resimden 2. Lenovo Y50-70 Touch Motherboard Replacement: adım 14, 3 resimden 3.
    • Use a Phillips #1 screwdriver to unscrew and remove the four 6 mm screws marked with red circles on the motherboard.
    • Grab and lift the motherboard up and out from the laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tanner Tomlinson
283 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 6-6, Beck Spring 2022 IUPUI, Team 6-6, Beck Spring 2022 üyesi
IUPUI-BECK-S22S6G6
4 Üyeler
3 adet Kılavuz yazıldı
Bir Yorum
Attempting this tomorrow soldiers, wish me luck o7
j.c.glaab - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 37
Her zaman: 1,145
