Ana içeriğe geç
Lenovo Y520-15IKBN Display Replacement
Neye ihtiyacın var
  1. Lenovo Y520-15IKBN Display Replacement, Battery: adım 1, 2 resimden 1. Lenovo Y520-15IKBN Display Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the four 4 mm Phillips #00 screws securing the battery.
  2. Lenovo Y520-15IKBN Display Replacement: adım 2, 2 resimden 1. Lenovo Y520-15IKBN Display Replacement: adım 2, 2 resimden 2.
    • Disconnect the battery connector by pulling the battery cable directly out of its port, toward the battery.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • If necessary, apply force and slowly wiggle the connector out of its socket. It should work its way out slowly.
  3. Lenovo Y520-15IKBN Display Replacement: adım 3, 1 resimden 1.
    • Lift the battery up and out of the chassis.
  4. Lenovo Y520-15IKBN Display Replacement, Display: adım 4, 1 resimden 1.
    • Use an opening tool to pry off the display bezel.
  5. Lenovo Y520-15IKBN Display Replacement: adım 5, 1 resimden 1.
    • Remove the four 4 mm screws with a Phillips #1 screwdriver.
  6. Lenovo Y520-15IKBN Display Replacement: adım 6, 1 resimden 1.
    • Flip up the gate on the display ribbon cable, and pull it directly out of its port.
    • Remove the display from the computer.
Sonuç
Mark A Clement
97 İtibar
1 Kılavuz yazıldı
Ekip
Comm 260 Team 15 Comm 260 Team 15 üyesi
Community
1 Üye
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 48
Her zaman: 1,640
