Ana içeriğe geç
Lenovo YOGA 730-15IKB Right Fan Replacement
Neye ihtiyacın var
  1. Lenovo YOGA 730-15IKB Right Fan Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo YOGA 730-15IKB Right Fan Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Right Fan Replacement: adım 2, 2 resimden 1. Lenovo YOGA 730-15IKB Right Fan Replacement: adım 2, 2 resimden 2.
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Right Fan Replacement: adım 3, 1 resimden 1.
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Right Fan Replacement, Right Fan: adım 4, 1 resimden 1.
    • When the laptop is upside down, the right fan is on the left side of the laptop near the large metal RAM cover.
    • Disconnect the fan cable. Pull the wire toward the back of the laptop while wiggling to loosen the connection.
    • You can also use the white tabs on the connector to push the cable free.
  5. Lenovo YOGA 730-15IKB Right Fan Replacement: adım 5, 2 resimden 1. Lenovo YOGA 730-15IKB Right Fan Replacement: adım 5, 2 resimden 2.
    • Remove two 4mm Phillips #1 screws.
  6. Lenovo YOGA 730-15IKB Right Fan Replacement: adım 6, 1 resimden 1.
    • Pull the fan up and towards the front of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Daniel Rodriguez Salinas
475 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G6, White Winter 2020 Cal Poly, Team S1-G6, White Winter 2020 üyesi
CPSU-WHITE-W20S1G6
3 Üyeler
27 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 49
Her zaman: 3,011
