Giriş
Follow this guide to replace the speakers in your Lenovo YOGA 730-15IKB.
Before replacing your speakers, make sure that you have ruled out any software audio issues. For example, make sure the volume is not muted and that the audio driver is installed.
Neye ihtiyacın var
Flip the laptop over so you can see the underside.
Remove the ten 7mm T5 Torx screws.
Pull the bottom cover up and away from the back hinges.
This is a perfect time to unplug the battery connector. This can save you from shorting something out. The battery terminal is easy to see and access.
Disconnect the speaker cable by pulling the wire towards the front of the laptop.
