Ana içeriğe geç
Lenovo YOGA 730-15IKB Touchpad Replacement
Neye ihtiyacın var
  1. Lenovo YOGA 730-15IKB Touchpad Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo YOGA 730-15IKB Touchpad Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Touchpad Replacement: adım 2, 2 resimden 1. Lenovo YOGA 730-15IKB Touchpad Replacement: adım 2, 2 resimden 2.
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Touchpad Replacement: adım 3, 1 resimden 1.
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Touchpad Replacement, Battery: adım 4, 3 resimden 1. Lenovo YOGA 730-15IKB Touchpad Replacement, Battery: adım 4, 3 resimden 2. Lenovo YOGA 730-15IKB Touchpad Replacement, Battery: adım 4, 3 resimden 3.
    • Disconnect the battery from the motherboard by gently pulling the battery cable using your fingers or a pair of tweezers.
    • Pull parallel to the battery, not straight up.
    • Unplug the cable gently as the eight wires on the connector are very small and delicate.
  5. Lenovo YOGA 730-15IKB Touchpad Replacement: adım 5, 2 resimden 1. Lenovo YOGA 730-15IKB Touchpad Replacement: adım 5, 2 resimden 2.
    • Remove the four 4mm Phillips #1 screws securing the battery.
  6. Lenovo YOGA 730-15IKB Touchpad Replacement: adım 6, 1 resimden 1.
    • Lift the battery up and out of the chassis.
    • Handle the battery carefully. Touching the terminal may cause electric shock. Puncturing the battery may cause it to catch fire.
  7. Lenovo YOGA 730-15IKB Touchpad Replacement, Touchpad: adım 7, 3 resimden 1. Lenovo YOGA 730-15IKB Touchpad Replacement, Touchpad: adım 7, 3 resimden 2. Lenovo YOGA 730-15IKB Touchpad Replacement, Touchpad: adım 7, 3 resimden 3.
    • The touchpad is connected by a ribbon cable to the front edge of the motherboard.
    • Pull up on the black tab on the touchpad cable connector.
    • The ribbon cable should easily pull out of the connector.
  8. Lenovo YOGA 730-15IKB Touchpad Replacement: adım 8, 1 resimden 1.
    • Remove six 2mm Phillips #000 screws.
    • Some of these screws may be hidden under other ribbon cables.
  9. Lenovo YOGA 730-15IKB Touchpad Replacement: adım 9, 2 resimden 1. Lenovo YOGA 730-15IKB Touchpad Replacement: adım 9, 2 resimden 2.
    • Pull up on the top edge of the touchpad near the motherboard. Lift the touchpad up and out of the chassis.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Daniel Rodriguez Salinas
448 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G6, White Winter 2020 Cal Poly, Team S1-G6, White Winter 2020 üyesi
CPSU-WHITE-W20S1G6
3 Üyeler
27 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 1,503
