Ana içeriğe geç
Lenovo YOGA 730-15IKB Wireless Card Replacement
Neye ihtiyacın var
  1. Lenovo YOGA 730-15IKB Wireless Card Replacement, Bottom Cover: adım 1, 2 resimden 1. Lenovo YOGA 730-15IKB Wireless Card Replacement, Bottom Cover: adım 1, 2 resimden 2.
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Wireless Card Replacement: adım 2, 2 resimden 1. Lenovo YOGA 730-15IKB Wireless Card Replacement: adım 2, 2 resimden 2.
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Wireless Card Replacement: adım 3, 1 resimden 1.
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Wireless Card Replacement, Wireless Card: adım 4, 1 resimden 1.
    • Remove the sticky tape from the top edge of the wireless card.
  5. Lenovo YOGA 730-15IKB Wireless Card Replacement: adım 5, 3 resimden 1. Lenovo YOGA 730-15IKB Wireless Card Replacement: adım 5, 3 resimden 2. Lenovo YOGA 730-15IKB Wireless Card Replacement: adım 5, 3 resimden 3.
    • Pull the black and white antenna wires off of the wireless card.
    • For reassembly, the white wire connects to the right terminal marked "1." The black wire connects to the left terminal marked "2."
  6. Lenovo YOGA 730-15IKB Wireless Card Replacement: adım 6, 2 resimden 1. Lenovo YOGA 730-15IKB Wireless Card Replacement: adım 6, 2 resimden 2.
    • Remove one 2mm Phillips #1 screw.
  7. Lenovo YOGA 730-15IKB Wireless Card Replacement: adım 7, 2 resimden 1. Lenovo YOGA 730-15IKB Wireless Card Replacement: adım 7, 2 resimden 2.
    • Pull the wireless card out of the socket at its resting angle.
    • Do not pull straight upward. Pull towards the hinges at the back of the laptop.
Sonuç
Ellis Ruckman
2.665 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S1-G6, White Winter 2020 Cal Poly, Team S1-G6, White Winter 2020 üyesi
CPSU-WHITE-W20S1G6
3 Üyeler
27 adet Kılavuz yazıldı
1Rehber Yorum
I was able to use an intel AX210NGW WiFi 6 & BT 5.3 to work perfectly - plug and play. It worked at startup. I get download speeds nearly 1,000 Mb/s on a WiFi 6 network. Well worth the upgrade.
George - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 59
Her zaman: 3,765
