Ana içeriğe geç
Lenovo YOGA 730-15IWL Battery Replacement
Neye ihtiyacın var
  1. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover screws: adım 1, 1 resimden 1.
    • Remove the screws (M2.0 x 7.0 mm, Torx).
  2. Lenovo YOGA 730-15IWL Battery Replacement, Remove the base cover: adım 2, 1 resimden 1.
    • Remove the base cover. Consider using a spudger.
  3. Lenovo YOGA 730-15IWL Battery Replacement, Remove the battery: adım 3, 1 resimden 1.
    • Unplug the battery connector in the direction shown by arrow
    • Remove the screws (M2.0 x 4.5 mm).
    • Remove the battery pack.
Sonuç
To replace the battery & reassemble your device, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Max Kletskov
40.910 İtibar
16 adet Kılavuz yazıldı
Ekip
The Home Depot The Home Depot üyesi
Community
18.172 Üyeler
140 adet Kılavuz yazıldı
2Kılavuz Yorumları
My issue with my Lenovo Yoga 730-15 laptop was not the battery I just successfully replaced. It still does not turn on. The Power button light up for a short time when pressed to power up the laptop. However, it then goes out and the laptop does not startup. Any Ideas?? Thanks
Al Cross - Yanıt
Check thermal paste. May be getting hot and shutting back off.
William Mobley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 78
Her zaman: 1,953
