Ana içeriğe geç
Lenovo Yoga 11e Chromebook Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 11e Chromebook Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • There will be 7 Philips head screws on the bottom which will need to be removed to gain access to the battery
    • NOTE: You may void your warranty completing this replacement
  2. Lenovo Yoga 11e Chromebook Keyboard Replacement: adım 2, 1 resimden 1.
    • There are two screws that will need to be removed to access the keyboard.
  3. Lenovo Yoga 11e Chromebook Keyboard Replacement: adım 3, 2 resimden 1. Lenovo Yoga 11e Chromebook Keyboard Replacement: adım 3, 2 resimden 2.
    • Next, flip the laptop over and open it up. The keyboard can be easily removed by pushing it back from the front. I suggest using a jimmy tool to slip into the tiny gap to push it back.
    • Look closely at the two images you'll notice a slight gap at the bottom if you did this step correctly
  4. Lenovo Yoga 11e Chromebook Keyboard Replacement: adım 4, 1 resimden 1.
    • Pull slightly up from the keyboard but NOT all the way, the ribbon cable is still connected to the motherboard
  5. Lenovo Yoga 11e Chromebook Keyboard Replacement: adım 5, 3 resimden 1. Lenovo Yoga 11e Chromebook Keyboard Replacement: adım 5, 3 resimden 2. Lenovo Yoga 11e Chromebook Keyboard Replacement: adım 5, 3 resimden 3.
    • Use a plastic pry tool to lift up the plastic clip holding down the ribbon cable. Be very gentle with it so it doesn't break
Sonuç
Congratulations you’ve successfully removed the keyboard! To reassemble your device, follow these instructions in reverse order.
3 farklı kişi bu kılavuzu tamamladı.
Corey Meyer
2.292 İtibar
2 adet Kılavuz yazıldı
Ekip
Kid fixers Kid fixers üyesi
Community
172 Üyeler
229 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 18
Her zaman: 1,929
