Ana içeriğe geç
Lenovo Yoga 2 11" 20428 Battery Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: adım 1, 3 resimden 1. Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: adım 1, 3 resimden 2. Lenovo Yoga 2 11" 20428 Battery Replacement, Back Panel: adım 1, 3 resimden 3.
    • Flip the computer over so the bottom is facing up.
    • Remove the ten 6mm screws with a T5 Torx security screwdriver.
  2. Lenovo Yoga 2 11" 20428 Battery Replacement: adım 2, 1 resimden 1.
    • Carefully remove the back panel by gently separating the panel from front to back.
    • Take care not to pull any wires or crack the outer shell.
  3. Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: adım 3, 3 resimden 1. Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: adım 3, 3 resimden 2. Lenovo Yoga 2 11" 20428 Battery Replacement, Battery: adım 3, 3 resimden 3.
    • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
    • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
  4. Lenovo Yoga 2 11" 20428 Battery Replacement: adım 4, 1 resimden 1.
    • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
  5. Lenovo Yoga 2 11" 20428 Battery Replacement: adım 5, 2 resimden 1. Lenovo Yoga 2 11" 20428 Battery Replacement: adım 5, 2 resimden 2.
    • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
    • If possible, do not to pull the connector out by the wires, as this can damage the connector.
  6. Lenovo Yoga 2 11" 20428 Battery Replacement: adım 6, 2 resimden 1. Lenovo Yoga 2 11" 20428 Battery Replacement: adım 6, 2 resimden 2.
    • Carefully remove the battery from the laptop.
    • Take care not to pull out the Bluetooth antenna while removing the battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 702
