Ana içeriğe geç
Lenovo Yoga 2 11" 20428 Display Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 2 11" 20428 Display Replacement, Display: adım 1, 2 resimden 1. Lenovo Yoga 2 11" 20428 Display Replacement, Display: adım 1, 2 resimden 2.
    • Remove the plastic square covers on the hinge cover.
  2. Lenovo Yoga 2 11" 20428 Display Replacement: adım 2, 2 resimden 1. Lenovo Yoga 2 11" 20428 Display Replacement: adım 2, 2 resimden 2.
    • Remove the two 3.8 mm screws from the hinge cover.
  3. Lenovo Yoga 2 11" 20428 Display Replacement: adım 3, 2 resimden 1. Lenovo Yoga 2 11" 20428 Display Replacement: adım 3, 2 resimden 2.
    • Remove the hinge cover.
  4. Lenovo Yoga 2 11" 20428 Display Replacement: adım 4, 3 resimden 1. Lenovo Yoga 2 11" 20428 Display Replacement: adım 4, 3 resimden 2. Lenovo Yoga 2 11" 20428 Display Replacement: adım 4, 3 resimden 3.
    • Remove the 2.8mm screws.
    • Remove the 5mm screws.
    • Remove the 2.4mm screws.
  5. Lenovo Yoga 2 11" 20428 Display Replacement: adım 5, 2 resimden 1. Lenovo Yoga 2 11" 20428 Display Replacement: adım 5, 2 resimden 2.
    • Remove the front cover of the display
  6. Lenovo Yoga 2 11" 20428 Display Replacement: adım 6, 1 resimden 1.
    • Unplug the button sensor board.
    • Do not damage the teeth. Damaging the teeth of the sensor board may require you to replace the part.
  7. Lenovo Yoga 2 11" 20428 Display Replacement: adım 7, 2 resimden 1. Lenovo Yoga 2 11" 20428 Display Replacement: adım 7, 2 resimden 2.
    • Remove the 2.1 mm screws from the brightness sensor board.
  8. Lenovo Yoga 2 11" 20428 Display Replacement: adım 8, 2 resimden 1. Lenovo Yoga 2 11" 20428 Display Replacement: adım 8, 2 resimden 2.
    • Remove the 3.3 mm screw on the camera.
    • Removal of the camera will result in the connecting wire to be disconnected as well
  9. Lenovo Yoga 2 11" 20428 Display Replacement: adım 9, 2 resimden 1. Lenovo Yoga 2 11" 20428 Display Replacement: adım 9, 2 resimden 2.
    • Remove the 3.3 mm screw on the touch control board.
  10. Lenovo Yoga 2 11" 20428 Display Replacement: adım 10, 2 resimden 1. Lenovo Yoga 2 11" 20428 Display Replacement: adım 10, 2 resimden 2.
    • Remove the touch control board
    • Do not damage the teeth. Damaging the teeth may call for replacement of the part.
    • Removal of the touch control board will result in the connecting wires to be removed as well
Sonuç
Bir başkası bu kılavuzu tamamladı.
Devin McCuen
181 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-3, Harley Spring 2022 IUPUI, Team 1-3, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S1G3
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 188
