Ana içeriğe geç
Lenovo Yoga 2 11" 20428 Keyboard Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Back Panel: adım 1, 3 resimden 1. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Back Panel: adım 1, 3 resimden 2. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Back Panel: adım 1, 3 resimden 3.
    • Flip the computer over so the bottom is facing up.
    • Remove the ten 6mm screws with a T5 Torx security screwdriver.
  2. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 2, 1 resimden 1.
    • Carefully remove the back panel by gently separating the panel from front to back.
    • Take care not to pull any wires or crack the outer shell.
  3. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Battery: adım 3, 3 resimden 1. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Battery: adım 3, 3 resimden 2. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Battery: adım 3, 3 resimden 3.
    • Use the Phillips #000 screwdriver to remove the six 3.3 mm screws around the perimeter of the battery.
    • Use the Phillips #000 screwdriver to remove the single 6.75 mm screw from the center of the battery.
  4. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 4, 1 resimden 1.
    • Gently remove the three pieces of tape securing the Bluetooth/Wi-Fi antenna.
  5. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 5, 2 resimden 1. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 5, 2 resimden 2.
    • Grip the base of the connector with your fingers or pliers, and gently pull the connector straight back towards you to remove it.
    • If possible, do not to pull the connector out by the wires, as this can damage the connector.
  6. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 6, 2 resimden 1. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 6, 2 resimden 2.
    • Carefully remove the battery from the laptop.
    • Take care not to pull out the Bluetooth antenna while removing the battery.
  7. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Speaker: adım 7, 1 resimden 1.
    • Use the Phillips #000 screwdriver to unscrew the four 1.7 mm screws.
  8. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 8, 2 resimden 1. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 8, 2 resimden 2.
    • Carefully detach the speaker wire and remove the speaker.
  9. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Hard Drive: adım 9, 1 resimden 1.
    • Use the Phillips #000 screwdriver to remove the four 3.3 mm screws securing the hard drive to the panel.
  10. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 10, 2 resimden 1. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 10, 2 resimden 2.
    • Lift the hard drive up, turn it over, and remove the connection.
  11. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Bluetooth Module: adım 11, 1 resimden 1.
    • Use the Phillips #000 screwdriver to remove the two 3.3 mm screws.
  12. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 12, 2 resimden 1. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 12, 2 resimden 2.
    • Gently grab and remove the Bluetooth module.
  13. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Motherboard: adım 13, 1 resimden 1.
    • Using your finger nail or a thin pry tool, unlock and remove the three cables.
    • Lift the two pieces of tape. Carefully pull the cable connector back to remove it from the motherboard.
    • Use the Phillips #000 screwdriver to remove the eight 3.8mm screws.
  14. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 14, 2 resimden 1. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 14, 2 resimden 2.
    • Gently pull the cable out of the connector.
  15. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 15, 2 resimden 1. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 15, 2 resimden 2.
    • Lift the wide cable in the center to reveal the port for the small cable underneath.
    • Using a fingernail or a thin pry tool, lift the white bar to release the cable.
    • Remove the cable from the connector.
  16. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 16, 1 resimden 1.
    • Lift the tape up to separate it from the motherboard.
    • Using a fingernail or a thin pry tool, lift the connector upwards to separate from the motherboard.
  17. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 17, 2 resimden 1. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 17, 2 resimden 2.
    • Remove the black tape covering the connector.
    • Pull straight backwards to remove the connector from the motherboard.
  18. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 18, 1 resimden 1.
    • Pull the cable straight backwards to remove it.
  19. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 19, 2 resimden 1. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 19, 2 resimden 2.
  20. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 20, 2 resimden 1. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 20, 2 resimden 2.
    • Use the Phillips #000 screwdriver to remove the seven 3.6mm screws.
  21. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 21, 1 resimden 1.
    • Lift and pull backwards to remove the motherboard.
  22. Lenovo Yoga 2 11" 20428 Keyboard Replacement, Keyboard: adım 22, 1 resimden 1.
    • Use the Phillips #000 screwdriver to unscrew and remove the one 3.3 mm screw that secures the daughterboard.
  23. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 23, 1 resimden 1.
    • Gently remove the daughterboard.
  24. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 24, 1 resimden 1.
    • Carefully remove all of the small black clips along the edge of the metal piece.
  25. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 25, 1 resimden 1.
    • Gently lift up and remove the two metal pieces, at the back of the bottom case, near the hinges.
  26. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 26, 1 resimden 1.
    • Gently lift up the metal cover and remove it.
  27. Lenovo Yoga 2 11" 20428 Keyboard Replacement: adım 27, 1 resimden 1.
    • Gently lift up the keyboard base and remove it.
Sonuç
To reassemble your Lenovo Yoga 2 11" (model 20428) keyboard, follow these instructions in reverse order.
Shalem
163 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-3, Harley Spring 2022 IUPUI, Team 1-3, Harley Spring 2022 üyesi
IUPUI-HARLEY-S22S1G3
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 481
