Ana içeriğe geç
Lenovo Yoga 2 11" Back Panel Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 2 11" Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Back Panel Replacement: adım 2, 1 resimden 1.
    • Carefully separate back panel from laptop.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Peyton Leeson
939 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-3, Maness Fall 2015 Cal Poly, Team 4-3, Maness Fall 2015 üyesi
CPSU-MANESS-F15S4G3
4 Üyeler
5 adet Kılavuz yazıldı
3 Yorum
Thanks for this manual.
Would you have the chance to add a photo of the machine without the cover on? My idea is to be able to see what is easily accessible in order to answer some other users' questions such as this one: Could I replace the hard drive with an SSD
dauffret - Yanıt
I believe the "hex screwdriver" is not the correct tool required...I believe it's the Torx screwdriver that would be the correct tool.
David Briggman - Yanıt
Not sure if the description has been updated since the 07/30/17 comment but the required tool is a T5 Torx screwdriver that is mentioned in the ‘Tools’ section…and they are not very common!
Ken Swanston - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 4,720
