Ana içeriğe geç
Lenovo Yoga 2 11" Battery Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 2 11" Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • With a T5 Torx screwdriver, remove ten 6.35 mm screws from the back of the laptop.
  2. Lenovo Yoga 2 11" Battery Replacement: adım 2, 1 resimden 1.
    • Carefully separate back panel from laptop.
  3. Lenovo Yoga 2 11" Battery Replacement, Battery: adım 3, 1 resimden 1.
    • Once you have completed the prerequisite guide, locate the battery of the laptop. Remember to disconnect the battery.
  4. Lenovo Yoga 2 11" Battery Replacement: adım 4, 1 resimden 1.
    • Using a #00 Philips Precision Screwdriver, remove the seven 3.175mm screws that hold the battery in place (six on the outside, one in the middle).
  5. Lenovo Yoga 2 11" Battery Replacement: adım 5, 2 resimden 1. Lenovo Yoga 2 11" Battery Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • There will be a clip that connects the battery to the rest of the laptop. Unclasp this clip by inserting tweezers into the connection to completely free the battery.
  6. Lenovo Yoga 2 11" Battery Replacement: adım 6, 1 resimden 1.
    • Once all of the wires are detached, carefully remove the battery and replace.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Abbey Hickmann
197 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 4-3, Maness Fall 2015 Cal Poly, Team 4-3, Maness Fall 2015 üyesi
CPSU-MANESS-F15S4G3
4 Üyeler
5 adet Kılavuz yazıldı
4 Yorum
how do I remove unathorized battery error?
Manuel Durugas - Yanıt
POOR INSTRUCTIONS
You have failed to mention that the battery cable is attached by a clip that requires opening.
Terrible.
You just took pictures of unscrewing. Not Useful.
barguybrady - Yanıt
Is it possible to use the computer without the battery? I.e. remove the battery and use the laptop with the power cable only.
Lasse E - Yanıt
The clip?😬how do you remove ?I tried a twizzer,didnt work ,and there a video ?
Estella - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 42
Her zaman: 26,592
