Ana içeriğe geç
Lenovo Yoga 2 13" Screen Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 2 13" Screen Replacement, Screen: adım 1, 2 resimden 1. Lenovo Yoga 2 13" Screen Replacement, Screen: adım 1, 2 resimden 2.
    • Using an opening pick, remove one small black rectangle piece on each of the hinge corners to locate screws.
    • Using a Phillips head screwdriver, carefully remove one 4.8 mm screw from each corner.
  2. Lenovo Yoga 2 13" Screen Replacement: adım 2, 1 resimden 1.
    • Using the Jimmy, remove the long centerpiece covering between the hinges.
  3. Lenovo Yoga 2 13" Screen Replacement: adım 3, 1 resimden 1.
    • Detach the screen from the front panel by sliding the screen up about 2mm. Do not pull too far, as there are still connected wires.
  4. Lenovo Yoga 2 13" Screen Replacement: adım 4, 1 resimden 1.
    • Locate the gold wire and follow it to two clips. Remove the clips and the clear tape securing the wire.
    • Gently unsnap the wire from the hooks along the perimeter, and remove any tape along the wire.
  5. Lenovo Yoga 2 13" Screen Replacement: adım 5, 2 resimden 1. Lenovo Yoga 2 13" Screen Replacement: adım 5, 2 resimden 2.
    • Completely separate the screen from the laptop.
    • During reassembly, remember to set the screen about 2 mm beyond the lid top edge. Then, slide down to engage the hinges.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Nichelle
1.550 İtibar
5 adet Kılavuz yazıldı
Ekip
Marist, Team 1-2, Laflen Spring 2015 Marist, Team 1-2, Laflen Spring 2015 üyesi
MARS-LAFLEN-S15S1G2
3 Üyeler
7 adet Kılavuz yazıldı
3 Yorum
Hi Nichelle,
thanks for your guide. Step 1 and 2 - no problem. But how actually did you do step 3? I can't detach the screen, I can just lift it a few millimeters at the corners or at the side, totally hard..
edit: Ok got it: slide the touch-lcd up a bit :)
Simon - Yanıt
Hey Nichelle, do you have any recommended vendors for both the screen and the digitizer? Thanks!
Emmanuel Duarte - Yanıt
I used laptopscreen.com.
ken - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 16,265
