Ana içeriğe geç
Lenovo Yoga 2 Pro SSD Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 2 Pro SSD Replacement, SSD: adım 1, 1 resimden 1.
    • Please ensure that the laptop is turned off before beginning.
    • Using a Phillips #00 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro SSD Replacement: adım 2, 1 resimden 1.
    • Gently lift off the back cover.
  3. Lenovo Yoga 2 Pro SSD Replacement: adım 3, 1 resimden 1.
    • Navigate to the top right corner of the laptop and locate the solid state drive next to the fan.
    • Using a Phillips #00 screwdriver, remove the one 3/16” screw from the top left corner of the solid state drive.
    • The solid state drive will lift up after you remove the screw.
  4. Lenovo Yoga 2 Pro SSD Replacement: adım 4, 2 resimden 1. Lenovo Yoga 2 Pro SSD Replacement: adım 4, 2 resimden 2.
    • To remove the solid state drive, gently slide it away from the battery and towards the hinges.
Sonuç
24 farklı kişi bu kılavuzu tamamladı.
Thomas Simko
2.546 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-14, Maness Fall 2015 Cal Poly, Team 12-14, Maness Fall 2015 üyesi
CPSU-MANESS-F15S12G14
5 Üyeler
13 adet Kılavuz yazıldı
7 Yorum
Thanks for the clarity of the presentation. I am having difficulty with Lenovo identifying and purchasing a 256 GB replacement SSD for my yoga pro 2 laptop. Any suggestions about what the specs of that drive might be and where I can find one would be most appreciated.
Charles Wantman - Yanıt
That looks like an M.2? I’m trying to figure that out myself, I’ll let you know if I find out.
Amethyst O'Connell -
Did you find it?  I would go to Amazon with part number mz-m5e250bw (it’s a Samsung card) … you don’t have to buy there.
I had to use a Torque #5 for the eleven screws on the back … the #00 Phillips was perfect for the SSD card itself.
jo diamond - Yanıt
How do you put the new one in? By reversing the process?
Lauren Neal - Yanıt
I am trying to find a reader for this old SSD. I purchased a M.2 NVME SATA SSD Enclosure Adapter, which I thought would work as a SATA PCIe M-Key(B+M Key) ssd reader but it doesn’t fit. Anyone point me towards a correct adapter?
YonA Dabs - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 89
Her zaman: 34,070
