Ana içeriğe geç
Lenovo Yoga 2 Pro Trackpad Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 2 Pro Trackpad Replacement, Battery: adım 1, 1 resimden 1.
    • Please ensure that the laptop is turned off before beginning.
    • Using a Phillips #00 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Trackpad Replacement: adım 2, 1 resimden 1.
    • Gently unclip and lift off the back cover.
  3. Lenovo Yoga 2 Pro Trackpad Replacement: adım 3, 1 resimden 1.
    • Using a Phillips #00 Screwdriver, remove the five 5/16" screws surrounding the battery.
  4. Lenovo Yoga 2 Pro Trackpad Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  5. Lenovo Yoga 2 Pro Trackpad Replacement: adım 5, 2 resimden 1. Lenovo Yoga 2 Pro Trackpad Replacement: adım 5, 2 resimden 2.
    • Remove the battery from the computer.
  6. Lenovo Yoga 2 Pro Trackpad Replacement, Trackpad: adım 6, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the eight 1/8" screws surrounding the trackpad.
  7. Lenovo Yoga 2 Pro Trackpad Replacement: adım 7, 1 resimden 1.
    • Using a sharp tool such as tweezers, lift up the black cover that is on top of the ribbon cable.
  8. Lenovo Yoga 2 Pro Trackpad Replacement: adım 8, 1 resimden 1.
    • With tweezers, gently slide the ribbon cable out from under the connector.
  9. Lenovo Yoga 2 Pro Trackpad Replacement: adım 9, 2 resimden 1. Lenovo Yoga 2 Pro Trackpad Replacement: adım 9, 2 resimden 2.
    • Lift the trackpad out of the computer.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Thomas Simko
2.546 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-14, Maness Fall 2015 Cal Poly, Team 12-14, Maness Fall 2015 üyesi
CPSU-MANESS-F15S12G14
5 Üyeler
13 adet Kılavuz yazıldı
3 Yorum
Where can I buy this trackpad? Mine is done.
Jorge Suarez - Yanıt
Same here. Where can I buy the part? I cannot even find a part number.
iwaniec - Yanıt
I got a lot of different options on ebay but cannot rely on them. I think we could order it from IBM FRU parts but only by email or phone at:
https://www-304.ibm.com/shop/americas/co...
FRU: 73040855
Will try tomorrow
LUIS GARZA - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 9,516
