Ana içeriğe geç
Lenovo Yoga 3 11 Audio Jack/USB Port Assembly Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 3 11 Audio Jack/USB Port Assembly Replacement, Lower Case: adım 1, 1 resimden 1.
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Audio Jack/USB Port Assembly Replacement, Audio Jack/USB Port Assembly: adım 2, 2 resimden 1. Lenovo Yoga 3 11 Audio Jack/USB Port Assembly Replacement, Audio Jack/USB Port Assembly: adım 2, 2 resimden 2.
    • Use a pair of tweezers to disconnect the ZIF connector securing the "IO Side" of the USB ribbon cable. Gently lift up the black tab on the connector and the ribbon cable should come free.
  3. Lenovo Yoga 3 11 Audio Jack/USB Port Assembly Replacement: adım 3, 3 resimden 1. Lenovo Yoga 3 11 Audio Jack/USB Port Assembly Replacement: adım 3, 3 resimden 2. Lenovo Yoga 3 11 Audio Jack/USB Port Assembly Replacement: adım 3, 3 resimden 3.
    • Remove the two 2 mm Phillips #00 screws securing the audio jack/USB port assembly.
    • Gently lift the audio jack/USB port assembly free of the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Slade Fernandes
532 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-3, Blackwell Fall 2015 USF Tampa, Team 2-3, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S2G3
4 Üyeler
11 adet Kılavuz yazıldı
Bir Yorum
Where can you purchase the part?
Steve Johnson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 2,988
