Ana içeriğe geç
Lenovo Yoga 3 11 Trackpad Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 3 11 Trackpad Replacement, Lower Case: adım 1, 1 resimden 1.
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Trackpad Replacement, Battery: adım 2, 3 resimden 1. Lenovo Yoga 3 11 Trackpad Replacement, Battery: adım 2, 3 resimden 2. Lenovo Yoga 3 11 Trackpad Replacement, Battery: adım 2, 3 resimden 3.
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Trackpad Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Trackpad Replacement: adım 4, 2 resimden 1. Lenovo Yoga 3 11 Trackpad Replacement: adım 4, 2 resimden 2.
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Trackpad Replacement: adım 5, 1 resimden 1.
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Trackpad Replacement, Trackpad: adım 6, 1 resimden 1.
    • Remove the four 2 mm Phillips #0 securing the trackpad.
  7. Lenovo Yoga 3 11 Trackpad Replacement: adım 7, 1 resimden 1.
    • Use the tweezers to partially remove the tape.
  8. Lenovo Yoga 3 11 Trackpad Replacement: adım 8, 2 resimden 1. Lenovo Yoga 3 11 Trackpad Replacement: adım 8, 2 resimden 2.
    • Use a pair of tweezers to disconnect the ZIF connector securing the trackpad ribbon cable. Gently lift up the black tab and the ribbon cable should come free.
  9. Lenovo Yoga 3 11 Trackpad Replacement: adım 9, 2 resimden 1. Lenovo Yoga 3 11 Trackpad Replacement: adım 9, 2 resimden 2.
    • Slightly push down with your thumb to pop out the trackpad.
    • The laptop must be slightly open in order for the trackpad to pop out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Slade Fernandes
532 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-3, Blackwell Fall 2015 USF Tampa, Team 2-3, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S2G3
4 Üyeler
11 adet Kılavuz yazıldı
Bir Yorum
Very brief, great illustrations. Now, I need to try it.
M T Martinez - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 2,913
