Ana içeriğe geç
Lenovo Yoga 3 11 Wireless Card Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 3 11 Wireless Card Replacement, Lower Case: adım 1, 1 resimden 1.
    • Remove the eleven 6 mm T5 Torx screws securing the lower case.
    • Gently lift the lower case up and away from the device.
  2. Lenovo Yoga 3 11 Wireless Card Replacement, Battery: adım 2, 3 resimden 1. Lenovo Yoga 3 11 Wireless Card Replacement, Battery: adım 2, 3 resimden 2. Lenovo Yoga 3 11 Wireless Card Replacement, Battery: adım 2, 3 resimden 3.
    • Remove the two 3 mm Phillips #00 screws securing the battery.
    • There are arrows on the battery indicating the location of the screws.
  3. Lenovo Yoga 3 11 Wireless Card Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to gently disconnect the battery connector.
  4. Lenovo Yoga 3 11 Wireless Card Replacement: adım 4, 2 resimden 1. Lenovo Yoga 3 11 Wireless Card Replacement: adım 4, 2 resimden 2.
    • Use a pair of tweezers to gently disconnect the speaker cable.
    • Remove the wires from underneath the battery tabs using the tweezers.
  5. Lenovo Yoga 3 11 Wireless Card Replacement: adım 5, 1 resimden 1.
    • Carefully remove the battery from the device.
  6. Lenovo Yoga 3 11 Wireless Card Replacement, Wireless Card: adım 6, 1 resimden 1.
    • Use a pair of tweezers to disconnect the motherboard-size of the trackpad ribbon cable. Gently lift up the black tab, and the cable should come free from the ZIF connector.
  7. Lenovo Yoga 3 11 Wireless Card Replacement: adım 7, 1 resimden 1.
    • Use a pair of tweezers to disconnect the keyboard ribbon cable from the motherboard ZIF connector. Gently lift up the white tab, and the cable should come free.
  8. Lenovo Yoga 3 11 Wireless Card Replacement: adım 8, 1 resimden 1.
    • Use a pair of tweezers to disconnect the motherboard-side of the SD board ribbon cable. Gently lift up the black tab, and then ribbon cable should come free from the ZIF connector.
  9. Lenovo Yoga 3 11 Wireless Card Replacement: adım 9, 1 resimden 1.
    • Use the tweezers to unplug the USB port from the motherboard by gently lifting the white connector up from the black motherboard connector.
  10. Lenovo Yoga 3 11 Wireless Card Replacement: adım 10, 1 resimden 1.
    • Use a plastic opening tool to gently pry up the screen cable from the motherboard.
  11. Lenovo Yoga 3 11 Wireless Card Replacement: adım 11, 3 resimden 1. Lenovo Yoga 3 11 Wireless Card Replacement: adım 11, 3 resimden 2. Lenovo Yoga 3 11 Wireless Card Replacement: adım 11, 3 resimden 3.
    • Use a pair of tweezers to disconnect the "I/O Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
    • Use a pair of tweezers to disconnect the "MB Side" of the ribbon cable connecting the audio jack/USB port assembly to the motherboard. Gently lift up the black tab, and the ribbon cable should come free from the ZIF connector.
    • Remove the ribbon cable from the device.
  12. Lenovo Yoga 3 11 Wireless Card Replacement: adım 12, 2 resimden 1. Lenovo Yoga 3 11 Wireless Card Replacement: adım 12, 2 resimden 2.
    • Remove the single 2 mm Phillips #00 screws securing the wireless card.
    • Use a pair of tweezers to disconnect the black and white antenna cables that are connected to the wireless card.
    • Gently lift the wireless card up and out of the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Geoff Wacker
91.064 İtibar
89 adet Kılavuz yazıldı
2 Yorum
Thanks for the useful views and explanations about what’s there, however I don’t see why the battery has to be removed at all for this procedure?
(The network card appears to be accessible without)
Pete R
Pete Reimann - Yanıt
Are there any H*ckintosh compatible wireless cards that can be installed in this Lenovo Yoga 3 11 laptop? Asking for a friend. ;)
Jaime Hancock - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 2,709
