Ana içeriğe geç
Lenovo Yoga 3 14 Cooling Fan Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 3 14 Cooling Fan Replacement, Back Case: adım 1, 1 resimden 1.
    • Remove the eleven 6mm T5 Torx screws from the back case.
  2. Lenovo Yoga 3 14 Cooling Fan Replacement: adım 2, 3 resimden 1. Lenovo Yoga 3 14 Cooling Fan Replacement: adım 2, 3 resimden 2. Lenovo Yoga 3 14 Cooling Fan Replacement: adım 2, 3 resimden 3.
    • Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
    • Gently lift the backing off the laptop.
  3. Lenovo Yoga 3 14 Cooling Fan Replacement, Cooling Fan: adım 3, 2 resimden 1. Lenovo Yoga 3 14 Cooling Fan Replacement, Cooling Fan: adım 3, 2 resimden 2.
    • Remove the two 3mm screws using the PH#0 screwdriver head.
    • Unscrew the three 4mm screws using PH#1 (the larger screws do not come off the are attached to the housing unit of the cooling fan).
  4. Lenovo Yoga 3 14 Cooling Fan Replacement: adım 4, 3 resimden 1. Lenovo Yoga 3 14 Cooling Fan Replacement: adım 4, 3 resimden 2. Lenovo Yoga 3 14 Cooling Fan Replacement: adım 4, 3 resimden 3.
    • Use tweezers to disconnect the fan.
    • Unwrap the white and black wires from around the fan case.
  5. Lenovo Yoga 3 14 Cooling Fan Replacement: adım 5, 1 resimden 1.
    • Gently lift the fan out of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matthew Victores
602 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-2, Passmore Fall 2016 USF Tampa, Team 3-2, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S3G2
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 3,156
