Ana içeriğe geç
Lenovo Yoga 3 14 Speaker Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 3 14 Speaker Replacement, Back Case: adım 1, 1 resimden 1.
    • Remove the eleven 6mm T5 Torx screws from the back case.
  2. Lenovo Yoga 3 14 Speaker Replacement: adım 2, 3 resimden 1. Lenovo Yoga 3 14 Speaker Replacement: adım 2, 3 resimden 2. Lenovo Yoga 3 14 Speaker Replacement: adım 2, 3 resimden 3.
    • Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
    • Gently lift the backing off the laptop.
  3. Lenovo Yoga 3 14 Speaker Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the four 3mm PH#0 screws surrounding the battery.
  4. Lenovo Yoga 3 14 Speaker Replacement: adım 4, 3 resimden 1. Lenovo Yoga 3 14 Speaker Replacement: adım 4, 3 resimden 2. Lenovo Yoga 3 14 Speaker Replacement: adım 4, 3 resimden 3.
    • Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop.
  5. Lenovo Yoga 3 14 Speaker Replacement, Speaker: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using a pair of tweezers, dissconnect the speakers on the left side of the laptop.
  6. Lenovo Yoga 3 14 Speaker Replacement: adım 6, 2 resimden 1. Lenovo Yoga 3 14 Speaker Replacement: adım 6, 2 resimden 2.
    • Flip up the black retaining flap on the ZIF connector.
    • Using tweezers, gently disconnect the blue strip that connects the touch pad to the motherboard.
  7. Lenovo Yoga 3 14 Speaker Replacement: adım 7, 2 resimden 1. Lenovo Yoga 3 14 Speaker Replacement: adım 7, 2 resimden 2.
    • Use tweezers to gently pull off tape that is holding down wires that are connecting the two speakers together.
  8. Lenovo Yoga 3 14 Speaker Replacement: adım 8, 2 resimden 1. Lenovo Yoga 3 14 Speaker Replacement: adım 8, 2 resimden 2.
    • Both speakers are held in place by plastic pegs. Gently lift the speakers off the casing to remove them.
  9. Lenovo Yoga 3 14 Speaker Replacement: adım 9, 2 resimden 1. Lenovo Yoga 3 14 Speaker Replacement: adım 9, 2 resimden 2.
    • Simply grip the speaker wires and lift away from laptop to remove.
Sonuç
Matthew Victores
602 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-2, Passmore Fall 2016 USF Tampa, Team 3-2, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S3G2
4 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 1,268
