Ana içeriğe geç
Lenovo Yoga 3 14 USB Port Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 3 14 USB Port Replacement, Back Case: adım 1, 1 resimden 1.
    • Remove the eleven 6mm T5 Torx screws from the back case.
  2. Lenovo Yoga 3 14 USB Port Replacement: adım 2, 3 resimden 1. Lenovo Yoga 3 14 USB Port Replacement: adım 2, 3 resimden 2. Lenovo Yoga 3 14 USB Port Replacement: adım 2, 3 resimden 3.
    • Insert the plastic opening tool into the long side of the case backing and slide it the entire length of the laptop.
    • Gently lift the backing off the laptop.
  3. Lenovo Yoga 3 14 USB Port Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the four 3mm PH#0 screws surrounding the battery.
  4. Lenovo Yoga 3 14 USB Port Replacement: adım 4, 3 resimden 1. Lenovo Yoga 3 14 USB Port Replacement: adım 4, 3 resimden 2. Lenovo Yoga 3 14 USB Port Replacement: adım 4, 3 resimden 3.
    • Gently lift the battery and use the plastic opening tool to remove the battery's connection to the laptop.
  5. Lenovo Yoga 3 14 USB Port Replacement, USB Port: adım 5, 2 resimden 1. Lenovo Yoga 3 14 USB Port Replacement, USB Port: adım 5, 2 resimden 2.
    • Take out the 3, 3mm screws from the left hinge using the PH0 head.
    • Remove the 1, 4mm screw that connects the hinge to the USB port.
    • Carefully lift the hinge enough to separate it from the USB port.
  6. Lenovo Yoga 3 14 USB Port Replacement: adım 6, 2 resimden 1. Lenovo Yoga 3 14 USB Port Replacement: adım 6, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using the tweezers, carefully lift the black clip and remove the electrical ribbon.
  7. Lenovo Yoga 3 14 USB Port Replacement: adım 7, 1 resimden 1.
    • The USB port is held in place by plastic pegs. Gently lift up to remove the USB port from the laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matthew Victores
602 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-2, Passmore Fall 2016 USF Tampa, Team 3-2, Passmore Fall 2016 üyesi
USFT-PASSMORE-F16S3G2
4 Üyeler
7 adet Kılavuz yazıldı
2 Yorum
Anyone know where I can buy this part? Cannot find it anywhere…
Nicolas Petersen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 2,136
