Giriş
This guide will outline the proper procedure for removal of the display assembly. Exercise caution while removing and handling the assembly and its components, as they can easily scratch. Remember to turn the laptop off prior to starting.
Neye ihtiyacın var
Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
Use the plastic opening tool to flip open the tab on each ribbon connector as shown.
Remove the four 2mm screws using the Philips 00 screwdriver.
Remove the 2.5mm screw using the Philips 00 screwdriver.
11 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Thank you. Very useful.
Great guide, but I think you missed the part of removing the fan
