Ana içeriğe geç
Lenovo Yoga 3 Pro Motherboard Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. Lenovo Yoga 3 Pro Motherboard Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo Yoga 3 Pro Motherboard Replacement, Back Panel: adım 1, 2 resimden 2.
    • Flip the laptop so that the back panel is facing up.
    • Remove the ten 4.0mm T6 Torx screws from the back of the laptop.
  2. Lenovo Yoga 3 Pro Motherboard Replacement: adım 2, 1 resimden 1.
    • Gently lift the back cover off of the laptop.
  3. Lenovo Yoga 3 Pro Motherboard Replacement, Battery: adım 3, 2 resimden 1. Lenovo Yoga 3 Pro Motherboard Replacement, Battery: adım 3, 2 resimden 2.
    • Push the black battery cable towards the battery to disconnect it.
  4. Lenovo Yoga 3 Pro Motherboard Replacement: adım 4, 2 resimden 1. Lenovo Yoga 3 Pro Motherboard Replacement: adım 4, 2 resimden 2.
    • Remove the six #0 3.8mm Phillips screws from the battery.
  5. Lenovo Yoga 3 Pro Motherboard Replacement: adım 5, 1 resimden 1.
    • Gently lift the battery out of the laptop chassis.
  6. Lenovo Yoga 3 Pro Motherboard Replacement, Wireless Card: adım 6, 2 resimden 1. Lenovo Yoga 3 Pro Motherboard Replacement, Wireless Card: adım 6, 2 resimden 2.
    • Using the plastic opening tool, gently pry the grey wire off the wifi card.
    • Pry the black wire off the wifi card.
  7. Lenovo Yoga 3 Pro Motherboard Replacement: adım 7, 1 resimden 1.
    • Remove the one #0 2.9mm Phillips screw from the base of the wifi card.
  8. Lenovo Yoga 3 Pro Motherboard Replacement: adım 8, 2 resimden 1. Lenovo Yoga 3 Pro Motherboard Replacement: adım 8, 2 resimden 2.
    • Gently lift and pull the wifi card out.
  9. Lenovo Yoga 3 Pro Motherboard Replacement, SSD: adım 9, 2 resimden 1. Lenovo Yoga 3 Pro Motherboard Replacement, SSD: adım 9, 2 resimden 2.
    • Remove the one #0 2.9mm Phillips screw from the SSD.
  10. Lenovo Yoga 3 Pro Motherboard Replacement: adım 10, 1 resimden 1.
    • Gently lift and wiggle the SSD side to side to remove it from the laptop chassis.
  11. Lenovo Yoga 3 Pro Motherboard Replacement, Motherboard: adım 11, 3 resimden 1. Lenovo Yoga 3 Pro Motherboard Replacement, Motherboard: adım 11, 3 resimden 2. Lenovo Yoga 3 Pro Motherboard Replacement, Motherboard: adım 11, 3 resimden 3.
    • Push the cable away from the motherboard.
  12. Lenovo Yoga 3 Pro Motherboard Replacement: adım 12, 3 resimden 1. Lenovo Yoga 3 Pro Motherboard Replacement: adım 12, 3 resimden 2. Lenovo Yoga 3 Pro Motherboard Replacement: adım 12, 3 resimden 3.
    • Remove the two #0 2.9mm Phillips screws from the daughter board.
  13. Lenovo Yoga 3 Pro Motherboard Replacement: adım 13, 1 resimden 1.
    • Lift the daughter board with the plastic opening tool.
    • You will hear two clicks when lifting the daughter board.
  14. Lenovo Yoga 3 Pro Motherboard Replacement: adım 14, 3 resimden 1. Lenovo Yoga 3 Pro Motherboard Replacement: adım 14, 3 resimden 2. Lenovo Yoga 3 Pro Motherboard Replacement: adım 14, 3 resimden 3.
    • Lift the daughter board, unrouting the wireless cables from their plastic holders, and place it to the side.
  15. Lenovo Yoga 3 Pro Motherboard Replacement: adım 15, 3 resimden 1. Lenovo Yoga 3 Pro Motherboard Replacement: adım 15, 3 resimden 2. Lenovo Yoga 3 Pro Motherboard Replacement: adım 15, 3 resimden 3.
    • Gently lift the metal tabs on the daughter board to free the wires.
  16. Lenovo Yoga 3 Pro Motherboard Replacement: adım 16, 3 resimden 1. Lenovo Yoga 3 Pro Motherboard Replacement: adım 16, 3 resimden 2. Lenovo Yoga 3 Pro Motherboard Replacement: adım 16, 3 resimden 3.
    • Detach the five flat flex cables attached to the motherboard as follows:
    • 1. Flip the cable holder up with a finger nail
    • 2. Pull on the tab to remove the cable.
    • The large black flat flex labeled 'MB' does not have a tab so gently tug the cable free from the end after flipping the cable holder.
  17. Lenovo Yoga 3 Pro Motherboard Replacement: adım 17, 3 resimden 1. Lenovo Yoga 3 Pro Motherboard Replacement: adım 17, 3 resimden 2. Lenovo Yoga 3 Pro Motherboard Replacement: adım 17, 3 resimden 3.
    • Remove the four #0 2.3mm Phillips screws holding down the motherboard.
    • Remove the two #0 2.9mm Phillips screws holding down the fan.
  18. Lenovo Yoga 3 Pro Motherboard Replacement: adım 18, 3 resimden 1. Lenovo Yoga 3 Pro Motherboard Replacement: adım 18, 3 resimden 2. Lenovo Yoga 3 Pro Motherboard Replacement: adım 18, 3 resimden 3.
    • Make sure the motherboard and fan are not caught on anything when flipping it over.
    • Gently lift and flip the motherboard over.
  19. Lenovo Yoga 3 Pro Motherboard Replacement: adım 19, 3 resimden 1. Lenovo Yoga 3 Pro Motherboard Replacement: adım 19, 3 resimden 2. Lenovo Yoga 3 Pro Motherboard Replacement: adım 19, 3 resimden 3.
    • Flip the cable lock holding down the monitor connector.
    • Remove the monitor connector by tugging on the tab.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Nathan Lui
848 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S13-G6, Forte Spring 2017 Cal Poly, Team S13-G6, Forte Spring 2017 üyesi
CPSU-FORTE-S17S13G6
4 Üyeler
12 adet Kılavuz yazıldı
2 Yorum
There is a tremendous difference between this model and the lenovo yoga 4 900-13ISK.
These instructions do not apply, but some steps are similar
corey - Yanıt
Hi. Do you have any idea where I could by a replacement motherboard and how much that would cost? Please answer to martin.loffler@gmail.com. Thank you so much. Best, Martin
Martin Loffler - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 21
Her zaman: 7,842
