Ana içeriğe geç
Lenovo Yoga 3 Pro Speakers Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 3 Pro Speakers Replacement, Battery: adım 1, 1 resimden 1.
    • Before opening your laptop, make sure it is powered off.
    • Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
  2. Lenovo Yoga 3 Pro Speakers Replacement: adım 2, 1 resimden 1.
    • Slide the plastic opening tool between the base cover and the frame to pry open the computer.
    • Slowly go around the entire perimeter of the computer until all edges are loose.
    • Make sure the plastic opening tool doesn't go too far into the device.
  3. Lenovo Yoga 3 Pro Speakers Replacement: adım 3, 1 resimden 1.
    • Remove the panel and place it in a safe location.
  4. Lenovo Yoga 3 Pro Speakers Replacement: adım 4, 1 resimden 1.
    • Remove the six 3.5 mm screws surrounding the battery using a Phillips 00 screwdriver.
  5. Lenovo Yoga 3 Pro Speakers Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  6. Lenovo Yoga 3 Pro Speakers Replacement: adım 6, 1 resimden 1.
    • Carefully lift and remove the battery.
  7. Lenovo Yoga 3 Pro Speakers Replacement, Speakers: adım 7, 1 resimden 1.
    • Remove the four 4 mm screws using the Phillips 00 screwdriver.
  8. Lenovo Yoga 3 Pro Speakers Replacement: adım 8, 2 resimden 1. Lenovo Yoga 3 Pro Speakers Replacement: adım 8, 2 resimden 2.
    • Using the plastic opening tool, flip open tab as shown.
  9. Lenovo Yoga 3 Pro Speakers Replacement: adım 9, 3 resimden 1. Lenovo Yoga 3 Pro Speakers Replacement: adım 9, 3 resimden 2. Lenovo Yoga 3 Pro Speakers Replacement: adım 9, 3 resimden 3.
    • Remove the adhesive tape.
    • Flip open the ribbon connecting tab.
    • Carefully lift the ribbon connector from its adhesive.
  10. Lenovo Yoga 3 Pro Speakers Replacement: adım 10, 2 resimden 1. Lenovo Yoga 3 Pro Speakers Replacement: adım 10, 2 resimden 2.
    • Remove the speaker and set it on the side.
    • Use the plastic opening tool to remove the cables.
    • Be careful of other cables.
  11. Lenovo Yoga 3 Pro Speakers Replacement: adım 11, 2 resimden 1. Lenovo Yoga 3 Pro Speakers Replacement: adım 11, 2 resimden 2.
    • Removing the other speaker by unwinding cables.
    • Lift both speakers carefully.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Caroline Seifert
541 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-17, Maness Fall 2015 Cal Poly, Team 12-17, Maness Fall 2015 üyesi
CPSU-MANESS-F15S12G17
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 2,798
