Giriş
Over time, the USB ports collect dust, dirt, and can become damaged for a multitude of reasons all of which ultimately lead to connectivity issues. This guide will help you remove the USB ports in order to clean or replace them.
Neye ihtiyacın var
Remove the ten 3.3 mm screws from the base cover using a T5 Torx screwdriver.
Use the plastic opening tool to flip open the tab on each ribbon connector as shown.
10 farklı kişi bu kılavuzu tamamladı.
4 Yorum
This guide helped me quite a bit today. I really appreciate you providing it.
None of the 3 USB ports were powering on.
Windows seemed happy and no drivers and bios update helped …
I took apart following this guide, cleaned all ports and PCBs with IPA and a toothbrush and now it’s all working again!
Thank you
