Giriş
The solid state drive stores data and works as a type of flash memory. Use this guide to remove the drive from your laptop if you would like to replace or upgrade it.
Neye ihtiyacın var
Flip your device so that the bottom panel is facing up.
Remove the eleven 5mm Torx T5 screws from the back panel.
Use a spudger to unclip clips on the front and near the USB ports on each side
Lift the back panel off
Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
Carefully remove the battery from the laptop.
Remove the one 2mm Phillips #1 screw holding the hard drive to the laptop.
8 farklı kişi bu kılavuzu tamamladı.
3 Yorum
How to transfer the windows os to the newly install Crucial ssd?
how to transfer the windows OS to the newly install ssd?
Your list of t7 screwdriver costed me to order a wrong one.
it should be T5 but the ad listed T7!!!!!
it is frustrating.
Remy Williams - Yanıt
Mine had T5 as well.
alan - Yanıt
