Ana içeriğe geç
Lenovo Yoga 700-11ISK Touchpad Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 700-11ISK Touchpad Replacement, Back Panel: adım 1, 2 resimden 1. Lenovo Yoga 700-11ISK Touchpad Replacement, Back Panel: adım 1, 2 resimden 2.
    • Flip your device so that the bottom panel is facing up.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Lenovo Yoga 700-11ISK Touchpad Replacement: adım 2, 1 resimden 1.
    • Use a spudger to unclip clips on the front and near the USB ports on each side
    • Lift the back panel off
  3. Lenovo Yoga 700-11ISK Touchpad Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the two 3mm Phillips #1 screws holding the battery to the laptop chassis.
    • Disconnect the battery from the IO board by holding the connector by the sides and gently pulling the connector out.
  4. Lenovo Yoga 700-11ISK Touchpad Replacement: adım 4, 1 resimden 1.
    • Carefully remove the battery from the laptop.
    • Make sure that all wires still connected to the laptop are out of the way and not pulled out with the battery.
  5. Lenovo Yoga 700-11ISK Touchpad Replacement, Touchpad: adım 5, 3 resimden 1. Lenovo Yoga 700-11ISK Touchpad Replacement, Touchpad: adım 5, 3 resimden 2. Lenovo Yoga 700-11ISK Touchpad Replacement, Touchpad: adım 5, 3 resimden 3.
    • Remove the four 4mm Phillips #1 screws holding the touchpad onto the laptop.
    • Use a spudger to lift up the two black tabs on the ZIF connectors and then pull the cable out by the blue tab.
    • The cable should slide in and out effortlessly. If there is resistance when pulling the cable, double check the black tabs.
  6. Lenovo Yoga 700-11ISK Touchpad Replacement: adım 6, 1 resimden 1.
    • Slightly separate the two halves of the laptop with one hand and slide the touchpad out from the laptop with the other.
    • There may be silver tape holding the touchpad to the laptop. You do not need to replace the tape when reassembling the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Sean Wong
859 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 15-6, Livingston Fall 2016 Cal Poly, Team 15-6, Livingston Fall 2016 üyesi
CPSU-LIVINGSTON-F16S15G6
4 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
The “Tools Required” section says “Torx T7” but Step 1 lists, and (more importantly) the actual device has Torx T5 screws.
Step 5 suggests using a spudger, so perhaps that should be listed too.
alan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 26
Her zaman: 2,236
