Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
The back panel protects the inside of your device from damage. If your back panel is broken, use this guide to replace it. Only remove this if your trying to replace something on the inside or the back panel itself.
  1. Make sure back panel is facing up. Remove eleven 5mm screws with the T5 Torx Screwdriver.
    • Make sure back panel is facing up.
    • Remove eleven 5mm screws with the T5 Torx Screwdriver.
  2. Nintendo Switch Setleri
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. Lift back panel carefully.
    • Lift back panel carefully.
    • You can now replace back cover, making sure to match screw holes and placement of the original.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Teairra Woods
249 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 774
