Ana içeriğe geç
Giriş
The back panel protects the inside of your device from damage. If your back panel is broken, use this guide to replace it. Only remove this if your trying to replace something on the inside or the back panel itself.
  1. Make sure back panel is facing up. Remove eleven 5mm screws with the T5 Torx Screwdriver.
    • Make sure back panel is facing up.
    • Remove eleven 5mm screws with the T5 Torx Screwdriver.
  2. Android Tamir Setleri
    Yeni bir ekran veya pil, bir tamir kiti kadar yakınında.
    Hemen Alışveriş Yapın
  3. Lift back panel carefully.
    • Lift back panel carefully.
    • You can now replace back cover, making sure to match screw holes and placement of the original.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Teairra Woods
249 İtibar
2 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 16
Her zaman: 721
