Ana içeriğe geç
Giriş
The Lenovo Yoga battery loses charge quickly. You have already tried unplugging it when it is fully charged, or adjusting the light to save energy. You may need to replace the battery. This guide will help you.
  1. Flip the device having the bottom panel facing you.
    • Flip the device having the bottom panel facing you.
    • Remove the eleven 5mm Torx T5 screws from the back panel.
  2. Remove the back panel carefully.
    • Remove the back panel carefully.
  3. Remove the two 3mm Phillips #1 screws that are holding the battery to the device. Hold the bundled cable connector on each side and carefully pull the connector to release it from the motherboard.
    • Remove the two 3mm Phillips #1 screws that are holding the battery to the device.
    • Hold the bundled cable connector on each side and carefully pull the connector to release it from the motherboard.
  4. Remove the battery carefully from the device.
    • Remove the battery carefully from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Teairra Woods
249 İtibar
2 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 30
Her zaman: 1,514
