Ana içeriğe geç
Lenovo Yoga 710-14IKB Battery Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 710-14IKB Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Battery Replacement: adım 2, 3 resimden 1. Lenovo Yoga 710-14IKB Battery Replacement: adım 2, 3 resimden 2. Lenovo Yoga 710-14IKB Battery Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Battery Replacement, Battery: adım 3, 2 resimden 1. Lenovo Yoga 710-14IKB Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Battery Replacement: adım 4, 2 resimden 1. Lenovo Yoga 710-14IKB Battery Replacement: adım 4, 2 resimden 2.
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Battery Replacement: adım 5, 1 resimden 1.
    • Remove the battery.
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
Grant Doerksen
1.005 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S14-G5, Banghart Spring 2017 Cal Poly, Team S14-G5, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S14G5
4 Üyeler
21 adet Kılavuz yazıldı
7 Yorum
Thank you for posting this battery replacement guide! I’m not huge on computer tech stuff and because of the holidays a lot of repair shops were closed. So, I found this, the tools I needed and bought a battery off ebay and I did it myself. I saved so much time and money(i’m sure) because of these simple instructions. Although I have the 710-15IKB, everything was basically identical. Thank you !
envykiss99 - Yanıt
Thank you making this guide for a battery replacement!
envykiss99 - Yanıt
I replaced the battery, but now the computer won’t turn on! what am I doing wrong?
chrismark1 - Yanıt
I you haven’t yet, try plugging the laptop into power to see if it runs off of AC power.
Arthur Shi -
Worked great. thx
John Smith - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 27
Son 30 gün: 129
Her zaman: 19,283
