Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
20 farklı kişi bu kılavuzu tamamladı.
7 Yorum
Thank you for posting this battery replacement guide! I’m not huge on computer tech stuff and because of the holidays a lot of repair shops were closed. So, I found this, the tools I needed and bought a battery off ebay and I did it myself. I saved so much time and money(i’m sure) because of these simple instructions. Although I have the 710-15IKB, everything was basically identical. Thank you !
Thank you making this guide for a battery replacement!
I replaced the battery, but now the computer won’t turn on! what am I doing wrong?
I you haven’t yet, try plugging the laptop into power to see if it runs off of AC power.
Worked great. thx
