Ana içeriğe geç
Lenovo Yoga 710-14IKB Fan Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 710-14IKB Fan Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Fan Replacement: adım 2, 3 resimden 1. Lenovo Yoga 710-14IKB Fan Replacement: adım 2, 3 resimden 2. Lenovo Yoga 710-14IKB Fan Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Fan Replacement, Fan: adım 3, 2 resimden 1. Lenovo Yoga 710-14IKB Fan Replacement, Fan: adım 3, 2 resimden 2.
    • Unscrew the the two 4mm Phillips #00 screws holding the fan in place.
    • Be careful not to break the thin plastic tabs on the fan casing.
  4. Lenovo Yoga 710-14IKB Fan Replacement: adım 4, 2 resimden 1. Lenovo Yoga 710-14IKB Fan Replacement: adım 4, 2 resimden 2.
    • Use your fingernail or a plastic tool to disconnect the fan power cable from the circuit board.
    • Slide it straight out of its socket.
  5. Lenovo Yoga 710-14IKB Fan Replacement: adım 5, 2 resimden 1. Lenovo Yoga 710-14IKB Fan Replacement: adım 5, 2 resimden 2.
    • Lift the fan up and out of its mount.
    • Be careful that the small plastic tabs don't get snagged on any other parts or cables.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Grant Doerksen
1.005 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S14-G5, Banghart Spring 2017 Cal Poly, Team S14-G5, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S14G5
4 Üyeler
21 adet Kılavuz yazıldı
4 Yorum
Thanks for a great guide! This is a great laptop with a really noisy cheep fan... It makes a high pitch sound even under the low load. Is it possible to make it run any better??
k.kubaitis - Yanıt
I have searched online for a replacement fan for the Yoga 710-14ikb but havent found any. Is it possible to use a fan for another model, perhaps the 14isk or 15ikb?
David Hansson - Yanıt
I did find this but dont want to wait that long. https://www.aliexpress.com/item/New-lapt...
edwardrmorley -
does anyone know the best place to buy a new one of these fans?
edwardrmorley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 3,389
