Ana içeriğe geç
Giriş
This guide will teach you how to remove and replace the cooling fan on your Lenovo Yoga laptop.
  1. Use a Torx T4 screwdriver to unscrew the 9 5mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 9 5mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover. The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard. The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Unscrew the the two 4mm Phillips #00 screws holding the fan in place. Be careful not to break the thin plastic tabs on the fan casing.
    • Unscrew the the two 4mm Phillips #00 screws holding the fan in place.
    • Be careful not to break the thin plastic tabs on the fan casing.
  4. Use your fingernail or a plastic tool to disconnect the fan power cable from the circuit board. Slide it straight out of its socket.
    • Use your fingernail or a plastic tool to disconnect the fan power cable from the circuit board.
    • Slide it straight out of its socket.
  5. Lift the fan up and out of its mount. Be careful that the small plastic tabs don't get snagged on any other parts or cables.
    • Lift the fan up and out of its mount.
    • Be careful that the small plastic tabs don't get snagged on any other parts or cables.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Grant Doerksen
786 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team S14-G5, Banghart Spring 2017 Cal Poly, Team S14-G5, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S14G5
4 Üyeler
8 adet Kılavuz yazıldı
4 Yorum
Thanks for a great guide! This is a great laptop with a really noisy cheep fan... It makes a high pitch sound even under the low load. Is it possible to make it run any better??
k.kubaitis - Yanıt
I have searched online for a replacement fan for the Yoga 710-14ikb but havent found any. Is it possible to use a fan for another model, perhaps the 14isk or 15ikb?
David Hansson - Yanıt
I did find this but dont want to wait that long. https://www.aliexpress.com/item/New-lapt...
edwardrmorley -
does anyone know the best place to buy a new one of these fans?
edwardrmorley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 2
Son 30 Gün: 32
Her zaman: 1,680
