Ana içeriğe geç
Giriş
This simple guide will show you how to remove the headphone jack circuitboard (which also has the SD card attached) from the Lenovo Yoga 710-14KB.
  1. Use a Torx T4 screwdriver to unscrew the 9 5mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 9 5mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover. The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard. The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Use the Phillips #00 screwdriver to remove the four 3mm screws holding the battery in place. Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
    • Use the Phillips #00 screwdriver to remove the four 3mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Use the blue plastic opening tool to disconnect the battery cable. Make sure to apply pressure upward and try not to wiggle the connector from side to side, as this could damage the connector. Make sure to apply pressure upward and try not to wiggle the connector from side to side, as this could damage the connector.
    • Use the blue plastic opening tool to disconnect the battery cable.
    • Make sure to apply pressure upward and try not to wiggle the connector from side to side, as this could damage the connector.
  5. Remove the two 3mm screws from the headphone jack using a PH00 screwdriver.
    • Remove the two 3mm screws from the headphone jack using a PH00 screwdriver.
    • Make sure not to strip the screws as they can sometimes be hard to remove.
  6. Pop the black bar on the tip of the wire connected to the headphone jack circuitboard.
    • Pop the black bar on the tip of the wire connected to the headphone jack circuitboard.
    • Disconnect the wire.
    • Be careful not to pull or yank the cable.
  7. Remove the headphone jack circuitboard. Remove the headphone jack circuitboard.
    • Remove the headphone jack circuitboard.
Sonuç
Evan Cruzen
205 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 üyesi
UMASSD-GULBRANDSEN-F18S5G8
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 7
Her zaman: 80
