Ana içeriğe geç
Lenovo Yoga 710-14IKB RAM Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 710-14IKB RAM Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB RAM Replacement: adım 2, 3 resimden 1. Lenovo Yoga 710-14IKB RAM Replacement: adım 2, 3 resimden 2. Lenovo Yoga 710-14IKB RAM Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB RAM Replacement, RAM: adım 3, 2 resimden 1. Lenovo Yoga 710-14IKB RAM Replacement, RAM: adım 3, 2 resimden 2.
    • Use blue plastic opening tool to pry the ram cover loose. Carefully lift up the ram cover and remove it from the laptop.
  4. Lenovo Yoga 710-14IKB RAM Replacement: adım 4, 2 resimden 1. Lenovo Yoga 710-14IKB RAM Replacement: adım 4, 2 resimden 2.
    • Locate the ram hold downs.
    • Push outwards on the hold downs to release the RAM.
  5. Lenovo Yoga 710-14IKB RAM Replacement: adım 5, 2 resimden 1. Lenovo Yoga 710-14IKB RAM Replacement: adım 5, 2 resimden 2.
    • Remove the RAM by pulling away from the RAM socket.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Grant Doerksen
1.005 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S14-G5, Banghart Spring 2017 Cal Poly, Team S14-G5, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S14G5
4 Üyeler
21 adet Kılavuz yazıldı
4 Yorum
Hi, can the RAM be expandable and what is the highest RAM expansion this lenovo YOGA 710-14IKB can take?
victoria - Yanıt
Hi Victoria, I replaced the 8GB RAM stick with a single 16GB RAM stick and this does work!
Johannes de Wit -
una pregunta, cuantas ranuras de memoria RAM tiene?
One question, how many RAM slots does it have?
andres arce - Yanıt
It has 1 RAM slot
Lil Youman -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 18
Son 30 gün: 47
Her zaman: 6,442
