Neye ihtiyacın var
Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
Use blue plastic opening tool to pry the ram cover loose. Carefully lift up the ram cover and remove it from the laptop.
14 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Hi, can the RAM be expandable and what is the highest RAM expansion this lenovo YOGA 710-14IKB can take?
Hi Victoria, I replaced the 8GB RAM stick with a single 16GB RAM stick and this does work!
una pregunta, cuantas ranuras de memoria RAM tiene?
One question, how many RAM slots does it have?
It has 1 RAM slot
