Ana içeriğe geç
Lenovo Yoga 710-14IKB SSD Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 710-14IKB SSD Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB SSD Replacement: adım 2, 3 resimden 1. Lenovo Yoga 710-14IKB SSD Replacement: adım 2, 3 resimden 2. Lenovo Yoga 710-14IKB SSD Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB SSD Replacement, SSD: adım 3, 2 resimden 1. Lenovo Yoga 710-14IKB SSD Replacement, SSD: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the 3mm screw on the SSD.
  4. Lenovo Yoga 710-14IKB SSD Replacement: adım 4, 2 resimden 1. Lenovo Yoga 710-14IKB SSD Replacement: adım 4, 2 resimden 2.
    • Use your fingers to lift up the SSD and pull away from the socket removing it from the laptop.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Grant Doerksen
1.005 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S14-G5, Banghart Spring 2017 Cal Poly, Team S14-G5, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S14G5
4 Üyeler
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 61
Her zaman: 11,201
