Ana içeriğe geç
Lenovo Yoga 710-14IKB Trackpad Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 710-14IKB Trackpad Replacement, Back Cover: adım 1, 1 resimden 1.
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Trackpad Replacement: adım 2, 3 resimden 1. Lenovo Yoga 710-14IKB Trackpad Replacement: adım 2, 3 resimden 2. Lenovo Yoga 710-14IKB Trackpad Replacement: adım 2, 3 resimden 3.
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Trackpad Replacement, Battery: adım 3, 2 resimden 1. Lenovo Yoga 710-14IKB Trackpad Replacement, Battery: adım 3, 2 resimden 2.
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Trackpad Replacement: adım 4, 2 resimden 1. Lenovo Yoga 710-14IKB Trackpad Replacement: adım 4, 2 resimden 2.
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Trackpad Replacement: adım 5, 1 resimden 1.
    • Remove the battery.
  6. Lenovo Yoga 710-14IKB Trackpad Replacement, Trackpad: adım 6, 1 resimden 1.
    • Use the Phillips #1 screwdriver to take off the three 3mm screws.
  7. Lenovo Yoga 710-14IKB Trackpad Replacement: adım 7, 2 resimden 1. Lenovo Yoga 710-14IKB Trackpad Replacement: adım 7, 2 resimden 2.
    • Grip the blue tab and pull out.
    • Careful to not pull too hard, there is a chance of damaging the tab.
  8. Lenovo Yoga 710-14IKB Trackpad Replacement: adım 8, 2 resimden 1. Lenovo Yoga 710-14IKB Trackpad Replacement: adım 8, 2 resimden 2.
    • Lift off the layer of tape from the trackpad.
  9. Lenovo Yoga 710-14IKB Trackpad Replacement: adım 9, 1 resimden 1.
    • Push out the trackpad.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chuefeng Vang
136 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 üyesi
UMASSD-GULBRANDSEN-F18S5G8
3 Üyeler
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 1,408
