Ana içeriğe geç
Giriş
This guide will demonstrate how to replace the Wi-Fi card in your Lenovo Yoga laptop.
  1. Use a Torx T4 screwdriver to unscrew the 9 5mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 9 5mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover. The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard. The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Peel off the black tape covering the top of the WiFi card. Remove the black and white antenna cable attached to the card by pulling them off using the precison tweezers. BE CAREFUL! The antenna socket is VERY FRAGILE. If you use brute force, the antenna socket on board (female) will be pull out with the male connector.
    • Peel off the black tape covering the top of the WiFi card.
    • Remove the black and white antenna cable attached to the card by pulling them off using the precison tweezers.
    • BE CAREFUL! The antenna socket is VERY FRAGILE. If you use brute force, the antenna socket on board (female) will be pull out with the male connector.
    • If you disconnect the antenna cable properly, the socket will remain undamaged like fig.3
  4. If you disconnect it with brute force, it will be damaged like that.
    • If you disconnect it with brute force, it will be damaged like that.
  5. Use a #00 Phillips screwdriver to remove the 3mm screw in the center at the top of the card.
    • Use a #00 Phillips screwdriver to remove the 3mm screw in the center at the top of the card.
  6. The WiFi Card should be unbound from the surface. Carefully remove the card from the laptop by puling away from the socket. The WiFi Card should be unbound from the surface. Carefully remove the card from the laptop by puling away from the socket. The WiFi Card should be unbound from the surface. Carefully remove the card from the laptop by puling away from the socket.
    • The WiFi Card should be unbound from the surface. Carefully remove the card from the laptop by puling away from the socket.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Grant Doerksen
786 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team S14-G5, Banghart Spring 2017 Cal Poly, Team S14-G5, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S14G5
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 Gün: 3
Son 30 Gün: 39
Her zaman: 1,180
