Ana içeriğe geç
Lenovo Yoga 710-15IKB Solid State Drive Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 710-15IKB Solid State Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Solid State Drive Replacement: adım 2, 1 resimden 1.
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Solid State Drive Replacement: adım 3, 1 resimden 1.
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Solid State Drive Replacement: adım 4, 1 resimden 1.
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Solid State Drive Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Solid State Drive Replacement: adım 6, 1 resimden 1.
    • Gently lift and remove the battery.
  7. Lenovo Yoga 710-15IKB Solid State Drive Replacement, Solid State Drive: adım 7, 1 resimden 1.
    • Remove the one JIS 1 screw holding the solid state drive in place.
  8. Lenovo Yoga 710-15IKB Solid State Drive Replacement: adım 8, 1 resimden 1.
    • Gently pull the solid state drive out and up to remove it from the connector.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Andrew Keenan
173 İtibar
1 Kılavuz yazıldı
Ekip
Bir Yorum
No need to remove battery. No need for tweezers.
Shane Whittet - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 54
Her zaman: 7,001
