Ana içeriğe geç
Lenovo Yoga 710-15IKB Trackpad Replacement
Neye ihtiyacın var
  1. Lenovo Yoga 710-15IKB Trackpad Replacement, Trackpad: adım 1, 1 resimden 1.
    • Remove the ten 3.3 mm screws from the base cover using the T5 Torx screwdriver.
  2. Lenovo Yoga 710-15IKB Trackpad Replacement: adım 2, 1 resimden 1.
    • Slide opening tool between the base and back cover.
  3. Lenovo Yoga 710-15IKB Trackpad Replacement: adım 3, 1 resimden 1.
    • Lift back cover.
  4. Lenovo Yoga 710-15IKB Trackpad Replacement: adım 4, 1 resimden 1.
    • Remove the four 3.5 mm screws around the battery using the Phillips 00 screwdriver.
  5. Lenovo Yoga 710-15IKB Trackpad Replacement: adım 5, 1 resimden 1.
    • Disconnect the battery from the motherboard.
  6. Lenovo Yoga 710-15IKB Trackpad Replacement: adım 6, 1 resimden 1.
    • Lift battery up gently to remove.
  7. Lenovo Yoga 710-15IKB Trackpad Replacement: adım 7, 1 resimden 1.
    • Use the JIS 1 screwdriver bit to unscrew the 3 screws.
  8. Lenovo Yoga 710-15IKB Trackpad Replacement: adım 8, 1 resimden 1.
    • Grip the tab firmly.
  9. Lenovo Yoga 710-15IKB Trackpad Replacement: adım 9, 1 resimden 1.
    • Pull tab until it disconnects from the trackpad. Be gentle - you do not want to damage any part of the tab.
  10. Lenovo Yoga 710-15IKB Trackpad Replacement: adım 10, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Gently lift the tape with angled tweezers.
  11. Lenovo Yoga 710-15IKB Trackpad Replacement: adım 11, 1 resimden 1.
    • Push the trackpad to remove it.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Hanna Deon
245 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 13
Her zaman: 3,256
